Old valve positioning
aurora22
aurora22 Member Posts: 32
I recently had to change the pressure valve. When closing the boiler feeding valve, this valve has not been moved in a long while. It did turn and close the valve. Problem is now once moved I can’t tell if this valve was open and how much. Is this valve supposed to be full closed or partially open
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    If you heard the water flow in , then your good ....
  • aurora22
    Water flow to fill system is ok. Can bring to 15 lbs. is this valve to be closed once filled?
  • Big Ed_4
    Some say to close off for very good reasons , if you do you just need to maintain pressure. ... Which is , Keep an eye on the system pressure ...
    EBEBRATT-Ed Member Posts: 20,180
    Is this HW or steam? I am assuming hot water. Does it have a PRV in the water line to control the system pressure? Does it have a backflow preventer?
