Boiler has code AO1
rafaelb1961
Member Posts: 1
in Gas Heating
My Aquabalance boiler does not reach set temp of 190°. It had a code of AO1. Had to reset boiler.
I did change the Iten 140 ignitor.
What should I be looking for now?
Hello @rafaelb1961,
Maybe condensate trap blocked ?
https://www.weil-mclain.com/sites/default/files/field-file/AquaBalance-Boiler-Manual-0118-Web.pdf
One Pipe System0 -
Is the gas turned on?
One Pipe System1
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 997 Plumbing
- 391 Solar
- 55 Water Quality
