Question about threading pipe with Ridgid 65-RA
I am threading some pipe with a Ridgid 65-RA and the threads appear to be NPS (they do not taper) like NPT.
I bought/installed a new set of dies (NPT), and threaded pipe. These threads are still not NPT (and the threaded pipe does not fit well into NPT fittings).
I am positive that I installed the dies correctly, and it does make clean threads, but any thoughts on what the problem may be? I would think NPT dies would make NPT threads, but what else may be going on?
Thanks!
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    Did you set in the new dies in series ? Check the markings.....
  • ChrisJ
    ChrisJ Member Posts: 17,343
    Thanks!
    I'm not familiar with a 65-RA?
    The 65R doesn't use the dies to create taper. It's a receding threader so as you thread it slowly retracts the dies away causing the taper.
    The only thought I have is did you set it for normal threads or accidently set it for oversized?
    Here's the instructions : https://cdn2.ridgid.com/resources/media?key=c7a4786e-92bb-460e-b59c-cc05bb6f6236&languageCode=en&type=document
  • dko
    dko Member Posts: 669
    If it was originally a BSPT threader, it can't use NPT dies.
    If BSPT dies require a BSPT threader, you can extrapolate that NPT dies require NPT threader.
  • rhodebump
    rhodebump Member Posts: 155
    That is so helpful! Thank you! You can't teach an old threader new threads ;)
  • rhodebump
    I am going to try one more time with my NPT dies and use exactly the standard depth setting. I did go beyond the standard setting thinking that it would create more threads on the pipe, not deeper ones.
  • KC_Jones
    KC_Jones Member Posts: 5,932
    Not sure if a visual would help anyone, but here is a listing on ebay showing a 65-RA threader.
    https://www.ebay.com/itm/153789535110
    2014 Weil Mclain EG-40
  • dko
    The difference between the letters at the end is only how it clamps/holds the pipe. Rest is the same
