Question about threading pipe with Ridgid 65-RA
rhodebump
Member Posts: 155
I am threading some pipe with a Ridgid 65-RA and the threads appear to be NPS (they do not taper) like NPT.
I bought/installed a new set of dies (NPT), and threaded pipe. These threads are still not NPT (and the threaded pipe does not fit well into NPT fittings).
I am positive that I installed the dies correctly, and it does make clean threads, but any thoughts on what the problem may be? I would think NPT dies would make NPT threads, but what else may be going on?
Thanks!
Thanks!
Did you set in the new dies in series ? Check the markings.....
I'm not familiar with a 65-RA?rhodebump said:I am threading some pipe with a Ridgid 65-RA and the threads appear to be NPS (they do not taper) like NPT.
Thanks!
The 65R doesn't use the dies to create taper. It's a receding threader so as you thread it slowly retracts the dies away causing the taper.
The only thought I have is did you set it for normal threads or accidently set it for oversized?
Here's the instructions : https://cdn2.ridgid.com/resources/media?key=c7a4786e-92bb-460e-b59c-cc05bb6f6236&languageCode=en&type=document
If it was originally a BSPT threader, it can't use NPT dies.
If BSPT dies require a BSPT threader, you can extrapolate that NPT dies require NPT threader.
That is so helpful! Thank you! You can't teach an old threader new threads
I am going to try one more time with my NPT dies and use exactly the standard depth setting. I did go beyond the standard setting thinking that it would create more threads on the pipe, not deeper ones.0
Not sure if a visual would help anyone, but here is a listing on ebay showing a 65-RA threader.
https://www.ebay.com/itm/1537895351100 -
The difference between the letters at the end is only how it clamps/holds the pipe. Rest is the same0
