Main Vent brand/ size
SPrivette
Member Posts: 1
I've got 2 radiators beyond this area that aren't getting any steam. I deduce its a clogged main air vent. I want to order a replacement for this one. Any ideas on the brand/ size?
I've got to move a lot in the basement to get back to this to replace it - would prefer to have the new vent in hand. I've already drained the system and adjusted the pressutrol to try to get the radiators to heat up. They have before but then stopped.
How long and what size are the mains?
At the absolute minimum you will need a Gorton #1, but depending on the main length, may need more than that. The old systems are typically way under vented for modern (post coal era) boilers.1 -
Looks like a tight spot, I'm not sure if a #2 would fit. They would need to take some measurements to see.Mad Dog_2 said:Make it simple..Gorton #2. Mad Dog 🐕
That capacity would do it for sure, I do agree with you there.0 -
@SPrivette , what is the height between the top edge of the elbow and the floor above?KC_Jones said:
That capacity would do it for sure, I do agree with you there.All Steamed Up, Inc.
Consulting0
- 50 Industry Classes
