Main Vent brand/ size
I've got 2 radiators beyond this area that aren't getting any steam. I deduce its a clogged main air vent. I want to order a replacement for this one. Any ideas on the brand/ size?
I've got to move a lot in the basement to get back to this to replace it - would prefer to have the new vent in hand. I've already drained the system and adjusted the pressutrol to try to get the radiators to heat up. They have before but then stopped.
  • KC_Jones
    KC_Jones Member Posts: 5,907
    How long and what size are the mains?
    At the absolute minimum you will need a Gorton #1, but depending on the main length, may need more than that. The old systems are typically way under vented for modern (post coal era) boilers.
    2014 Weil Mclain EG-40
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,382
    Make it simple..Gorton #2.  Mad Dog 🐕
  • KC_Jones
    Looks like a tight spot, I'm not sure if a #2 would fit. They would need to take some measurements to see.
    That capacity would do it for sure, I do agree with you there.
    Steamhead Member Posts: 18,187
    @SPrivette , what is the height between the top edge of the elbow and the floor above?
    Consulting
