High domestic side pressure??
DIYmark
Member Posts: 5
I’m not sure what’s wrong. I have a HTP light duty water heater separated from the heating loop by a heat exchanger. When I was running my system before connecting the thermostat and relay the pressure stayed fine. Now when it get up to temp , the presses rising by nearly 90 psi. Enough to open the t&p valve and have water trickling out. Any advice would be greatly appreciated
Do I need an air vent in the side with the water heater or should I be adding an expansion tank ? Is airlock a thing?0
Is this the pressure in the domestic hot water? If there is any form of check or pressure reducing valve on your domestic water supply, you absolutely have to have a domestic water rated expansion tank on the domestic hot water. If you are on a private well, you already have one (the pump control expansion tank).Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
Yes, there is a check valve and this is on the domestic supply side and I have city water. Thank you for confirming what I need to do. I have an expansion tank that I just need to plumb in. Can you tell me what pressure i should charge the tank to? the water pressure that comes into my house at about 53 psi.Jamie Hall said:Is this the pressure in the domestic hot water? If there is any form of check or pressure reducing valve on your domestic water supply, you absolutely have to have a domestic water rated expansion tank on the domestic hot water. If you are on a private well, you already have one (the pump control expansion tank).
Also, does the tank need to be on the cold side of the water heater ? Or can I add it to the hot side where I have more room ?0
Thanks everybody for your help. I installed a 2 gallon domestic expansion tank to my 50 gallon water heater yesterday. I charged the tank to 55 PSI which is the pressure that comes into my house from the city. Watching my pressure gauge as my system operated i noticed the PSI rise only slightly to around 60 PSI. Is this a normal increase?0
