Boiler releasing a lot of water ( munckin boiler)
P4murnane
Member Posts: 1
in Gas Heating
The water drain on bottom is producing a half a gallon of water a day sometimes more . Water pump got burnt out and waiting on new one but should it be pumping this much water out? Live in New England
That's condensate and it's a byproduct of combustion with a modulating condensing boiler.
It's normal. I assume you are waiting for a new condensate pump?0 -
At 171 there should not be much water flowing from that tube?
What is the smaller Pex tube connected to?Bob "hot rod" Rohr
Living the hydronic dream0
