Boiler releasing a lot of water ( munckin boiler)
P4murnane
P4murnane Member Posts: 1
The water drain on bottom is producing a half a gallon of water a day sometimes more . Water pump got burnt out and waiting on new one but should it be pumping this much water out?  Live in New England
  • SuperTech
    SuperTech Member Posts: 2,669
    That's condensate and it's a byproduct of combustion with a modulating condensing boiler.
    It's normal. I assume you are waiting for a new condensate pump?
    hot_rod Member Posts: 27,840
    At 171 there should not be much water flowing from that tube?
    What is the smaller Pex tube connected to?
