Does anyone know what this is above the boiler flue?
chicop9
chicop9 Member Posts: 1
Hello everyone, this is a Thatcher boiler. I think it is a Thatcher red king oil boiler that was converted to gas. The house was built in 1940 and the model number on the boiler says 056. I have been trying to purchase a manual or book to help me learn more about the boiler but no luck since the company closed in 1968. We purchased the house in 1988. I need to learn how to do a treatment flush, because my Dad used to do it and I used to help him sometimes but now I forgot how to do it. I just remember it was not that difficult, but I have brainfog from grief. He passed away recently. Any info is much appreciated! Thanks!
  • kcopp
    kcopp Member Posts: 4,663
    I believe that is/ was a tankless coil.
    STEVEusaPAchicop9reggi
  • bburd
    bburd Member Posts: 1,294
    edited January 2024
    I had one of those on a boiler from 1947. I think it's a predecessor to the tankless coil, because there was not nearly enough heating surface on the coil to heat water on demand and it was attached to a separate storage tank. Water circulated between the two by gravity. It's a built-in version of the old-fashioned side arm water heaters that were used with storage tanks.
    @op:  You can safely ignore that part, it's been disconnected. You must have a separate domestic water heater.
    Bburd
    chicop9
    EBEBRATT-Ed Member Posts: 20,085
    @bburd
    They called them "Tank Heaters" just like a tankless but smaller because the DHW was stored in a tank just like you said. Good way to plug a chimney opening when you don't have anything I guess.
    bburdchicop9
    HVACNUT Member Posts: 7,410
    Side Shot taps.
