Water hammer
khills2
Member Posts: 8
After my radiators finish heating a banging occurs in my ceiling (between 1st and 2bd floor) anywhere from 20 min to an hour after boiler turns off. It’s the same spot in ceiling each time. I know the radiator that the piping goes to.
Any ideas on how to stop this water hammer?
The water can't hammer if it can drain freely. Sounds obvious enough, but... so you need to figure out what might be pitched in such a way that the water can drain.
However, that much delay almost sounds as though it might be an expansion -- or perhaps more accurately, contraction -- noise.Br. Jamie, osb
With that assumption or contraction, would I need to put some type of padding around the pipe to muffle the sound?0
- 50 Industry Classes
