Compression tank makers?
delcrossv
Member Posts: 2,203
I recall someone posting here, a while ago, a company that makes small 10-15 gal compression ( no bladder) tanks. I've lost the bookmark so if you can post your suggestions here, I'd appreciate it.
It wasn't a big name like Amtrol, Thrush, or B&G.
Bell and Gossett sells Wessels brand steel compression tanks
in that size and larger ones as well.
I have a 15 gallon steel compression tank hanging in the
ceiling of my boiler/laundry room.
You can order them from your local Bell and Gossett dealer.
Are you replacing a galvanized tank that has reached its useful
life or doing a new installation?0 -
Adding an airtrol and probably won't be able to get the 1/2" plug out of the existing tank. So, I'll put in both new.
These look really small, smaller then Wessels makes.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Go with galvanized or plain steel? Piping is copper.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Thanks Bob, I'd appreciate that.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
I think they will sell directly to you?Bob "hot rod" Rohr
Living the hydronic dream1 -
Awesome! Thanks!Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Quality Tanks Inc.
Clinton, Wisconsin
https://qualitytanksinc.com/
(608) 676-2281
They are awesome! Very nice people, and like the name says, QUALITY. I'm very happy with my Quality tank. My highest recommendation.
They own two fabrication businesses that operate out of the same building.
- 50 Industry Classes
