Compression tank makers?
delcrossv
delcrossv Member Posts: 2,204
I recall someone posting here, a while ago, a company that makes small 10-15 gal compression ( no bladder) tanks. I've lost the bookmark so if you can post your suggestions here, I'd appreciate it.
It wasn't a big name like Amtrol, Thrush, or B&G.
  • leonz
    leonz Member Posts: 1,865
    edited January 2024
    Bell and Gossett sells Wessels brand steel compression tanks
    in that size and larger ones as well.
    I have a 15 gallon steel compression tank hanging in the
    ceiling of my boiler/laundry room.
    You can order them from your local Bell and Gossett dealer.
    Are you replacing a galvanized tank that has reached its useful
    life or doing a new installation?
  • delcrossv
    edited January 2024
    Adding an airtrol and probably won't be able to get the 1/2" plug out of the existing tank. So, I'll put in both new.
    These look really small, smaller then Wessels makes.
    EdTheHeaterMan Member Posts: 12,508
  • delcrossv
    Go with galvanized or plain steel? Piping is copper.
    hot_rod Member Posts: 27,856
    A shop in Wisconsin welds them, I’ll find the name. Or Wessel directly.
    delcrossv
  • delcrossv
    Thanks Bob, I'd appreciate that.
    I think they will sell directly to you?
    delcrossv
  • delcrossv
    Awesome! Thanks!
  • WMno57
    WMno57 Member Posts: 1,408
    Quality Tanks Inc.
    Clinton, Wisconsin
    https://qualitytanksinc.com/
    (608) 676-2281
    They are awesome! Very nice people, and like the name says, QUALITY. I'm very happy with my Quality tank. My highest recommendation.
    They own two fabrication businesses that operate out of the same building.
    delcrossv
  • Karl Reynolds
    Karl Reynolds Member Posts: 84
    I have a customer in Colorado with an abundance of brand new tanks in stock. Trenton Cheney 970-379-4222.
    delcrossv
