Beckett XL 2 stage pump vs standard model
gator
Member Posts: 26
in Oil Heating
So. Need some expert opinons - I have killer gravity feed - it keeps coming like crazy if you break a line open. I finally stuck shut off valves both sides of filter. But, the run is prob 30’ long or gone or take. Will in your opinion j need a XL 2 stage pump. Just curious.
What’s the drop? What’s the inlet pressure on the fuel unit?
-1 -
I’m not sure I just no it runs like a mother if you have the line off open it up. Lots of gravity feed. Very good flow.0
Then you should have an oil safety valve properly installed.gator said:I’m not sure I just no it runs like a mother if you have the line off open it up. Lots of gravity feed. Very good flow.
1
