Beckett XL 2 stage pump vs standard model
gator
gator Member Posts: 26
So. Need some expert opinons - I have killer gravity feed - it keeps coming like crazy if you break a line open. I finally stuck shut off valves both sides of filter. But, the run is prob 30’ long or gone or take. Will in your opinion j need a XL 2 stage pump.  Just curious.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,545
    edited January 2024
    No....A two stage pump is needed for the higher lift from tank . If you have a good gravity feed the two stage upgrade is not needed.....
    gator
  • STEVEusaPA
    What’s the drop? What’s the inlet pressure on the fuel unit?
  • gator
    I’m not sure I just no it runs like a mother if you have the line off open it up. Lots of gravity feed. Very good flow.
  • STEVEusaPA
    Then you should have an oil safety valve properly installed.
    gator
