Reconnecting a different old cast iron radiator to existing supply lines - 1/2" Valve
HandyFS
HandyFS Member Posts: 125
edited January 2024 in Oil Heating
I'm installing an old cast iron radiator to a hot water setup that is slightly shorter than the original one that was in this space. The old one was connected to copper supply lines and had a 1/2" Hot Water Radiator Valve and union that was not angled and went horizontal. Seems like all radiator vales sold are all angled. Do non-angled radiator valves and unions exist in 1/2"?
Here is a photo of what I mean
The only thing I can find in 1/2" for a radiator valve is something like this:
https://www.supplyhouse.com/Honeywell-Home-V2040DSL15-1-2-Horizontal-Valve-For-Standard-Capacity-Radiator
What are my options here? A part of me is thinking this radiator will probably never come out again, so I was considering using a steel connector into the radiator, and then coupling it with a brass connector onto the existing copper line and skipping a valve/union all together.
I can get some pictures if that's more helpful.
Any tips appreciated.
