Adding recirculating pump to Bradford White water heater
Do I need to remove the heat traps from my Bradford White water heater before installing a Watts recirculating pump?
thanks everyone
    hot_rod Member Posts: 27,339
    The trapper nipples are to prevent gravity or thermo siphon. The circulator will open them with no problem
    Will the system have a timer  or temperature control?
  • tlittle4life
    tlittle4life Member Posts: 2
    It will have a timer and a sensor to open the loop at 90 degrees.
