Adding recirculating pump to Bradford White water heater
tlittle4life
Member Posts: 2
Do I need to remove the heat traps from my Bradford White water heater before installing a Watts recirculating pump?
thanks everyone
thanks everyone
The trapper nipples are to prevent gravity or thermo siphon. The circulator will open them with no problem
Will the system have a timer or temperature control?Bob "hot rod" Rohr
Living the hydronic dream0 -
It will have a timer and a sensor to open the loop at 90 degrees.0
- 125 Chimneys & Flues
- 19 Recall Announcements
