OS fitting on one pipe steam
keith123
keith123 Member Posts: 105
Anyone ever see this ?
  • keith123
    It looked familiar to me. I vaguely remembered it from your seminar but never seen one in the flesh. I was confused on why it would be on a one pipe steam main. It’s one way to protect the main vent.
    The steam guy must’ve stolen it from the hot water guy
    Steamhead Member Posts: 18,345
    Maybe they were using it to keep water from splashing up into the vent.
    Consulting
    keith123Ironman
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,691
    I don’t think we will ever know.
    Retired and loving it.
    mattmia2 Member Posts: 16,214
    What does the rest of the piping look like? This isnt a "we saw huge pipes and assumed it was steam but it was actually gravity hot water so we bought a boiler with steam trim and tried to make it work" is it?
  • Waher
    Waher Member Posts: 372
    The bulbous bulge is to help the flow of condensate slip past air/steam without creating turbulence. Someone posted a picture of a similar fitting connected to a radiator valve recently. I think those tees were meant for use on multi-story risers in one pipe steam systems where the radiators were directly off the riser. Someone used the same type of tee at the main vent to try and protect the main vent from potential water hammer.
  • DanHolohan
  • dko
    dko Member Posts: 669
    Maybe one the reasons why the old green painted hoffman 75 lasted so long
    Interesting use of the fitting!
