hand pumped oil tank gauge
leonz
leonz Member Posts: 1,812
I cannot find the comment I made about a buried tank oil gauge that worked when you pumped the plunger under the wall mounted gauge and I do not remember the name of the company that made them :(.
    EBEBRATT-Ed Member Posts: 20,180
    Petrometer gauges. Don't know if they are still made. Supply House lists them as out of stock. See attached
  • STEVEusaPA
    They're are still made, and doing well in NY.
  • leonz
    edited January 2024
    Thank you, I forgot the name of the company that makes them.
    I figured that if and when the time comes that I have to switch from burning Coal to kerosene or fuel alcohol I wanted to use a petrometer and a 550 gallon highland double wall petrohopper tank to solve that issue as the old Riello burner I have is so old I can no longer by parts for and the upright 275 gallon tank is 37 years old and is almost empty.
