hand pumped oil tank gauge
leonz
Member Posts: 1,848
in Oil Heating
I cannot find the comment I made about a buried tank oil gauge that worked when you pumped the plunger under the wall mounted gauge and I do not remember the name of the company that made them
Petrometer gauges. Don't know if they are still made. Supply House lists them as out of stock. See attached0
They're are still made, and doing well in NY.
Thank you, I forgot the name of the company that makes them.
I figured that if and when the time comes that I have to switch from burning Coal to kerosene or fuel alcohol I wanted to use a petrometer and a 550 gallon highland double wall petrohopper tank to solve that issue as the old Riello burner I have is so old I can no longer by parts for and the upright 275 gallon tank is 37 years old and is almost empty.
- 125 Chimneys & Flues
