Radiant heat new bathroom
Jdnyc1133
Member Posts: 1
Hi all -
I'm new here and need some help. I live in an old house with hydronic heating. I'm converting the laundry room into a bathroom with radiant heat. What thermostat should I get to control the radiant heat. It will be the only heat source in the bathroom...
I read some threads where they were talking about outdoor reset/ set it and forget it, while using forced air as well. But all I will have is the hydronic radiant heat...
Plumber is going to run the pipes in the next couple of days. Do I need to have him place a sensor before pouring concrete on top? Or anything else for temperature control?
Please advise.
Please advise.
Tekmar radiant T Stat with sensor....very simple. Make sure the radiant output can meet the room heatloss...sometimes it can't and you need additional radiation besides the in mud tubing. Mad Dog 🐕0
This is a nice radiant stat that allows a combination air and floor sensor.
With a floor minimum setting you can keep the floor warm even when the AC is running
Living the hydronic dream0
