Sight glass gasket removal
Ozmat
Member Posts: 26
What is the proper way to remove the now rock hard rubber gasket from the nut that the sight glass inserts into. Can I through it my oven on a self clean cycle, stink up the house, make the wife angry, and distort the nuts? Use a propane torch? Soak it in carburetor cleane? Gasoline? Or, is there a better option?
I don't do this much so I'd bet someone on here has a much easier faster way.
But, the way I'd go about it is put on some glasses and use the smallest flathead screwdriver you've got and pry / bust them out. They will likely crumble pretty good once you push them far enough.
nuts are inexpensive,
nuts, washers, and gaskets,known to beat dead horses0 -
I try to soften them up with WD-40 or such.
Then I have found that an angled dental pick helps to dig out.0 -
Thanks for the comments. The nuts are only 60 years old and in good shape, so I think I will try to reuse them. I will let you know what happens. Thanks again.0
- 50 Industry Classes
