Part needed!!! Desperate!!
Tracy16
Member Posts: 9
I am looking for a water jacket (heat exchanger) for a Munchkin 199MASMER1
please!!!! Help!
please!!!! Help!
Thank you- Merry Christmas!
I am told it is a 2005 R1 and stainless steel0
I am in WA but will make anything work….0
I plan to do so in a few months but it isn’t an option this month…. I just need it to run a bit longer. It is timing and weather. We will be redoing the whole system!0
Nope - won’t work 🥺0
eBay one isn’t gonna work- Urg!0
HTP doesn't sell it. I talked to them years ago about a 140M HX. I was very dismayed. Some people have talked about welding a leak in the Munchkin stainless HX. It depend on where the leak is. The manifolds on the Hx has o-rings, I am told, and may be replaceable.0
I have a very tiny pin hole….I will take a used one to tide me over and get it working for now. A new system is in the works but can’t be done yet and I need heat!Thank you for the advice.0
- 123 Chimneys & Flues
