Part needed!!! Desperate!!
I am looking for a water jacket (heat exchanger) for a Munchkin 199MASMER1
please!!!! Help!
Thank you- Merry Christmas!
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    1. Where are you located ?
    2. Is it a 199 M...ASME rated boiler? Can you post a picture of the Model/serial number and the HX in need of replacement.
    I May have a used HX.
    Tracy16
  • Tracy16
    Tracy16 Member Posts: 9
  • Tracy16
    I am told it is a 2005 R1 and stainless steel
  • Tracy16
    I am in WA but will make anything work….
  • Ironman
    Ironman Member Posts: 7,827
    Replacing the boiler may be a more viable option.
    Bob Boan
    HomerJSmithapexmechSuperTech
  • Tracy16
    edited December 2023
    I plan to do so in a few months but it isn’t an option this month…. I just need it to run a bit longer. It is timing and weather. We will be redoing the whole system!
  • Tracy16
    Nope - won’t work 🥺
  • Tracy16
    eBay one isn’t gonna work- Urg!
  • HomerJSmith
    HomerJSmith Member Posts: 2,680
    HTP doesn't sell it. I talked to them years ago about a 140M HX. I was very dismayed. Some people have talked about welding a leak in the Munchkin stainless HX. It depend on where the leak is. The manifolds on the Hx has o-rings, I am told, and may be replaceable.
  • Tracy16
    I have a very tiny pin hole….
    I will take a used one to tide me over and get it working for now. A new system is in the works but can’t be done yet and I need heat!
    Thank you for the advice.
  • Tracy16
    dko I wish I could hug you!!!
    I am trying to set up pick up right now! Thank you!!!!
    WMno57SuperTechLe John
