Fuel pump seizing
HeatingHelp
Administrator Posts: 722
This discussion was created from comments split from: Oil pumps won't stop seizing / previous biodiesel use.
Hi nick1304 or opt101, did either of you ever solve your fuel pump seizing issues? I'm having the same problem. I've had the fuel pump and motor replaced 3 times, new fuel lines, a tiger loop, and a new tank installed within a 6 week time period and still the pump seizes up. I've had 3 different companies come to troubleshoot/repair but none seem to have a solid idea of what's going on. I only replaced the oil tank to rule out an oil issue. I don't think that's what's going on, but if anyone has any further thoughts, please let me know.
All the lines and connectors were put together with pipe dope to rule out the Teflon tape debate going on in some of the threads here (although pipe dope can cause clogs too if its sloppily applied and gets in that tube opening. I'm starting to wonder if that's it). I have a one pipe steam system. Boiler was installed 5 years ago but it looks like they gave me a used one (Weil McClain, says it was made in 2006). I've also been noticing that it's short cycling, even though I've been draining it and adding fresh water. Could the pump be seizing due to vacuums created in the steam line?0 -
Hi @mp23 , welcome to HeatingHelp. There are techs here who can answer your questions.
@Erin Holohan Haskell could you start a new discussion for mp23 please?
@mp23
Can you post some pictures of the oil tank oil lines burner and boiler and we will try and help you out.
The oil pump issue seizing has nothing to do with steam lines or vacuum.
Why are you draining and adding water? That has nothing to do with the oil pump but can shorten the boiler life.
One question. Did they pump oil out of your old tank into the new tank?0 -
@mp23, welcome to Heating Help! I've created a new discussion for you so that your post doesn't get lost in an older thread.
President
HeatingHelp.com0
- 50 Industry Classes
