Amana 80% goes to lock out mode
Jimmian
Member Posts: 1
in Gas Heating
Amana 80% goes to lock out mode after lightning a first burner for one second. Changed the flame sensor, new filter, cleaned intake pipe.
No idea…..please help.
Need pictures. Is it a standing pilot, electric ignition or a hot surface ignitor? Is the pilot lighting? You said the first burner lights do you mean the main burner? How many main burners are their?0
Damp, humid location? Crossovers are clogged.
If you're not sure, it might be better left to a pro. Sometimes the whole gas train needs to be removed. The orifices can be checked that way as well.0
