$100 and a little work, with a whole lot of heat
JShep
Member Posts: 23
$100, some cleaning brushes, wire brushes, and a handful of cans of high heat black paint turned a massive radiator buried under a stack in a second hand store into a monster. Loaded into my car with a forklift… unloaded by me with a 16’ long ramp I built out of scrap in the basement onto a sled I build with a pair of dollies and some scrap butcher block for cleanup, then wheeled around the block to the front where I had to enlist the help of a friend to get it up a step and a half inside.
Gotta get a picture of it installed someday.
Jeff
Baltimore
Baltimore
6
OK but high heat paint is wasted on a radiator that gets to 212
looks great.0
What a beauty! American Rococo?All Steamed Up, Inc.
Consulting1 -
It does look good. That's an old timer.0
Outstanding...that is a hydronic treasure...thanks for saving and honoring it. Mad Dog 🐕1
The stove paint I've seen needs to be slowly heated to something like 600f to fully cure.ethicalpaul said:OK but high heat paint is wasted on a radiator that gets to 212
I don't know what that actually means though.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Steamhead said:What a beauty! American Rococo?
That feels right, but I’ve spent most of time my in the basement in recent weeks breaking 2-3” fittings between floor joists… so it’s been a while since I looked at it.Jeff
Baltimore0 -
Your enthusiasm is admirable.
Nice job JShep. Where there was a will, you found a way.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
