Where can I find this radiator
rlc311
Member Posts: 2
I'm trying to find a replacement radiator.This is what I know. The radiators are built like older cast iron radiators for steam applications and suspended over the toilet in the bathroom.Measuring:
Length 25"
Height 15"
Depth 2-1/2"
There are (4) 1" female fitting on the corners.
Anyone know where I can find this or what an alternative would be?
I work for a property management company and the engineer asked for help finding these because he needs to replace them. I'm not sure what is wrong with the existing units.0
There is a radiator salvage company called Wagner Salvage that has lots of radiators. they have an eBay store online to look at the different options available. They will ship, but it ain't cheep. But might be cheeper that shipping brand spankin' new ones. https://www.ebay.com/str/wagnersalvage?_pgn=2 and they have a facebook page https://www.facebook.com/wagner.salvage
These are some old notes from Dan Holohan:
Get in touch with Fran Fehey at A-1 New & Used Plumbing & Heating Supply in Somerville, MA. This place is like a supermarket of old radiators. Fran reconditions and tests each one and he ships anywhere. His email address is: A1plumbing@rcn.com. and his website is http://www.antiqueplumbingandradiators.com
Also in New England is Vermont Salvage. See their website at http://www.vermontsalvage.com. A lot more than radiators here!
There's another terrific supplier in Montreal, Canada. They are Shafter Bros., Inc. Check out their website at: http://www.steamexperts.com/rads/
If you're in the Washington D.C. area, check out The Brass Knob. They also have a website: http://www.thebrassknob.com/
And if you're in Michigan, try Atlas Plumbing Supply, 3439 Gratiot Ave., Detroit, MI 48207
Two btu per sq ft for degree difference for a slab1 -
I was Crestfallen when Fran Scuttled A1. However, I did make it there a few years before. I brought about 5 "Large" (5K) cash 💸 with me to outfit Old Hitchcock Farmhouse with about 8 restored, scrolled, fancy Steam Rads for my Brand New Vapor system. I had collected the other 5 outta old Long Island 🏝 Goldcoast Great Gatsby Mansions I figured I had enough. I had enough for ONLY 3, but they were awesome. All these old scrap yards are almost gone in The Greater New York Area I know of one in the Bronx left. Mad Dog 🐕0
@Nick_Castrads may be able to help.
We've also compiled this list of where to find used radiators: https://heatinghelp.com/systems-help-center/where-to-find-used-radiators/President
HeatingHelp.com1 -
@Grallert, @kcopp is on the money - it's a Runtal, not ours.
@rlc311 we can definitely help you out with cast iron repalcements. Pipe centers may not be exactly the same though which could cause you some issues. If you send me your contact details to nick@castrads.com, I'll get in touch with specifics.
The closest model we have has an interaxis distance of 16 ⅔", so there'd be a bit of work to do - perhaps you could bring the steam trap down by using a close nipple above the elbow.
@Erin Holohan Haskell thanks for the recommendation.
3 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
