An Important Skill for Teaching Tradespeople
HeatingHelp
Administrator Posts: 722
Props can come in handy when you're trying to explain mechanical concepts.
2
Dan, maybe in a year or so you will think of something you want to write. You're a writer.
I did use a prop when I was teaching electrical to the HVAC students at the union hall.
If you're in a cellar for instance and want to run a wire or a pipe to something upstairs and have nothing to measure from you drill a pilot hole. (A small pilot hole in case you're in the wrong spot) Take a metal coat hanger and cut a piece of it and put it in a drill. Cut the drilling end on a 45 with pliers. And drill away. The hole will be so small if you're in the wrong spot no one will notice.
I dragged a short piece of pressure treated 6 X 6 wood to class one night and asked them if they thought the coat hanger would go through it. No one thought it would so we made a few bets. I won but all the money went into the Pizza Fund.1 -
Never say never!DanHolohan said:Thanks, but the fork is firmly in place. 😅0 -
Dan, The last two paragraphs are particularly rich! They deserve to be turned into a poster, put up on the wall as a reminder of where humanity lives. Thankyou!
Yours, Larry0
- 50 Industry Classes
