Beckett R7184b
Eadacorp
Eadacorp Member Posts: 1
Turns on starts pumping (no flame) , no oil out of the pump to nozzle ….  Solenoid not being powered. Does show 120v for a millisecond but goes to zero.  The Solenoid has no ohms .  It’s the control bad or just solenoid
    Steamhead Member Posts: 18,499
    Probably the control. But if you have a suitable cord, you can power the valve directly with 120V to make sure.
    Consulting
