Question about near-boiler piping
The system has not exhibited any issues. So, my question is it worth having this addressed or should I leave well-enough alone?
If it Ain't Broke, Don't Fix It
Some systems, when piped that way have problems... Some don't. If you are not experiencing any problems, then leave it be. There are no efficiency advantages to changing it, or any other advantages for that matter.Edward Young Retired
5 -
To be very clear, the manual shows an example of a main, not that you are only allowed one main connection. Each main should be connected individually to the header, yours is in the wrong place, but it should be connected separately. The manual cannot account for all situations, so it's showing where the main(s) should be connected, in your case that's two.
All that said, if it's working leave it, but definitely fix it if it's ever replaced.1 -
Thank you all.0
I'm not going to touch it, but just want to make sure I understand. Are you saying the two mains would come off the header between the right riser and equalizer? Is it not recommended to have the one supply like in the manual and then tee it off to the two mains?KC_Jones said:To be very clear, the manual shows an example of a main, not that you are only allowed one main connection. Each main should be connected individually to the header, yours is in the wrong place, but it should be connected separately. The manual cannot account for all situations, so it's showing where the main(s) should be connected, in your case that's two.
All that said, if it's working leave it, but definitely fix it if it's ever replaced.0 -
Yes, that's what he's saying. No, it is not recommended to have one supply with a tee. In practice, I doubt anyone could tell much difference unless it was a very large boiler with a large header into a single small riser that then tee'd.
IDK,
there's a guy around here that will pipe things in glass, and now I even hear he has begun installing flow indicators in said glass pipings , , ,
bet he could come up with a video or 2 and determine flow descrepancies, or not
# @ethicalpaulknown to beat dead horses2
- 50 Industry Classes
