Home depot radiator vents hissing thru entire steam cycle
They are junk. I buy a lot from HD but never vents
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
What brand do you buy? Is the Maid-o-mist brand any good?ethicalpaul said:They are junk. I buy a lot from HD but never vents
branimal said:What brand do you buy? Is the Maid-o-mist brand any good?
MoM and Gorton are nearly identical (I’ve looked inside and used both). I like both.
MoM are crimped not soldered and that freaks some people out but I’ve not seen one leak.
MoM have interchangeable (not adjustable) orifices which provides for easy swapping during balancing.
MoM are less $$ but I notice the price is closer in recent years.
I'm going to have to cash in my 401(k) and try a Hoffman some day, If I was speccing, marking up, and reselling vents for a living, I might pick Hoffman 😅
That's a great question .... I have no idea if the system is balanced or not. I started reading Dan Holohan's "Lost Art of Steam Heating" and never got very far. I need to get back to it.dabrakeman said:
Is your system currently pretty well balanced? What are on the other radiators currently?
The other radiators are still running on old vents. I pulled one this morning - it's a Maid-O-Mist.
If those are similar to old HD usav vents they are adjustable by turning the cap. It could be there are set to wide open and you can adjust down. Not the best vent but I have seen some work fine for years.0
I've tried the newer HD adjustable vents. They would let steam out of the air hole.nde said:If those are similar to old HD usav vents they are adjustable by turning the cap. It could be there are set to wide open and you can adjust down. Not the best vent but I have seen some work fine for years.
I believe they are showing a dislike for the vents you purchased from LOWES last year.
if you get enough of them, The LOWES vents will start Booo ing the HD VentsEdward Young Retired
My local hdwr store used to sell those, the adjustment didnothing on the two I had and they strted to pass steam within a year. i ended up replacing everything with MOM about 7=8 years ago and have not had a problem since.
Some now say the MOM are now crap. all i can say is they worked without issue when I bought mine and were less than half the price.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 52 Industry Classes
