Boiler stopped working
Frankbig23
Member Posts: 5
I have a crown gas spark fired steam boiler. Was installed maybe 3 years ago. Got home from work and it wasnt on. Jumped the thermostat didnt kick on. I cleaned the low water probe it wasnt really dirty. I took the pressurtrol off and blew out the pig tail then i jumped the trol still nothing. Damper is open and every 15 mins i see the led come on for the cycle guard lwco intermittent test. Im thinking there must be an electric issue any advice on where to start?
Check the draft hood spill switch or flame roll out. Most likely the spill switch as you stated the damper is open so those two devices would be in series after the damper end switch. Hard to believe you would have a plugged HX after 2-1/2 years so i'm leaning towards the spill switch. If the spill switch has failed you need to find the cause. It's a safety device. You might have animals nesting on top of your chimney, dead birds at the base, etc. spill switch should be re-settable by pressing the button in the middle0
Any lights on the Crown control board?I DIY.0
pedmec said:Check the draft hood spill switch or flame roll out. Most likely the spill switch as you stated the damper is open so those two devices would be in series after the damper end switch. Hard to believe you would have a plugged HX after 2-1/2 years so i'm leaning towards the spill switch. If the spill switch has failed you need to find the cause. It's a safety device. You might have animals nesting on top of your chimney, dead birds at the base, etc. spill switch should be re-settable by pressing the button in the middle0
WMno57 said:Any lights on the Crown control board?0
I had to go to work when im home ill get pictures0
This looks to be the same set up i have CROWN BOILERCrown Boiler BSI172ENP 172 MBH Gas-Fired Fully Assembled Steam Boiler0
Hello @Frankbig23,
Probably something in the Yellow boxes. A Multi-meter would help.
Damper End Switch.
FRS - Flame Roll Out Switch.
BVS - Blocked Vent Switch.
Ignition Module.
https://www.velocityboilerworks.com/documents/bermuda_installation_manual_2012.pdf
One Pipe System0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 27 Recall Announcements
