condensate pipe not properly plumbed
mrspeeder
mrspeeder Member Posts: 16
edited November 2023 in Plumbing
Hi,
my contractor didn't properly build the condensate pipe for my 2 rheem hvac units. One of them leaked and went into the bedrooms and now I have a hole in my ceiling. The contractor isnt answering my calls so thats another issue.
I have 2 units, one on the crawl space one in the attic. I want to properly build the condensate drain pipes with traps and whatever is needed. Any diy instructions for this?
Thanks!
    pecmsg Member Posts: 4,878
    Does that Attic get below freezing?
    JUGHNE
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,081
    I'm not an AC guy, but I usually see a 3/4" pvc tee with a 6 " piece sticking straight for a vent.  Mad Dog 🐕
  • mrspeeder
    It's possible that the AC could go below freezing but not likely.
    How would I properly pipe this?
    Not the unit but the area it’s located!
  • mrspeeder
    @pecmsg sorry yes, its possible the attic will go below freezing but I haven't seen it since the heat is always cycling.
