Nest Power Adaptor with external transformer on a Taco SR506 6 zone
How are the white wires hooked up?Br. Jamie, osb
If you only have two wires to the Nest you're going to have issues. The Nests have batteries that need recharging.0
Why happened to the company you paid to install it?
One white wire (labeled C) is hooked to the blue coming from the transformerJamie Hall said:How are the white wires hooked up?
The other two white wires (labeled R and W) are connected to the associated Zone
The grey wires (labeled R and W) are connected to the associated two wires going to the thermostat
A red wire from the transformer is connected to the R wire connected to the zone
Sorry if this isn't clear0 -
understood that is what the nest power adaptor is forEBEBRATT-Ed said:If you only have two wires to the Nest you're going to have issues. The Nests have batteries that need recharging.
I will be talking to them on MondaySTEVEusaPA said:Why happened to the company you paid to install it?
Hello @Johstacy,
I think they have too many wires going to too many places. All the zones should be basically independent except the NEST power adapters connections to the additional transformer.
So all the wires that function as Red on the thermostat side get connected together and to the transformer.
The Blue (C or Common) goes to your 5 NEST power adapters and the transformer.
The output side of the NEST power adapter, R and W goes to the appropriate zones of the Taco SR506.
Notice on the NEST power adapters the thermostat side is a group of two wires and the output side is a group of three wires.
You may want to pick one zone and chase it out and see if there is any unnecessary wires and/or connections.
Seems like they have extra Red wires going to the Taco SR506 terminals, where I would expect only one wire to each terminal of Taco SR506.
Also when only the necessary wires are connected correctly you may have to reverse the R and W at the Taco SR506 TT terminals since it looks like yours is an older SR506 unit. Look near the end of this post.
https://forum.heatinghelp.com/discussion/178485/old-t-t-taco-sr506-with-5-zones-looking-to-convert-to-5-nests-transformer-questions
BTW if wiring changes are needed shut everything off and check that all the wiring is correct before re-energizing.
Here is 3 of the your 5 zones so you can get the idea.
One Pipe System1 -
Your a rock star... This is the correct solution Thank you109A_5 said:Hello @Johstacy,
- 117 Geothermal
