In-floor oxypex question
du015
du015 Member Posts: 1
Hello All,
I was cutting for the toilet flange and had to go a bit wide due to obstructions below the floor. I hit some oxypex. Picture below. How would you guys fix this?! I imagine it’s pex-b so I don’t think an expansion fitting is an option. And I would like to avoid chipping up tile as the tile guys aren’t here. Do I just have to chip away around the pex with a dremmel or something until I can fit push-to-connect fittings? Any help would be hugely appreciated.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,062
    Hi, What is underneath? I'd be tempted to cut back a foot on each side and install a piece of PEX that clears the toilet with some spare room. Leave the connections exposed if you can. just in case.
    Yours, Larry
  • GroundUp
    GroundUp Member Posts: 2,503
    What does the owner of the property want to do? Ultimately, it's their decision.
    hot_rod Member Posts: 27,259
    Carefully chip away as much as possible and see if you have enough flex to add two crimp couplings
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Infloor radiant and Wax seals are not the best match..Imagine heat melting wax the seal which will cause the Toilet to leak at the base. :(
    I would repair it as Larry has suggested. :)
  • psb75
    psb75 Member Posts: 1,118
    Start by removing large sections of tile. Much of the repair will be under the toilet base. Your choice of
    the place to cut the hole was a large gamble with "not good" odds.
