Riello LP burner on Biasi B10-4 boiler
PilotWerx
PilotWerx Member Posts: 8
Hoping someone can help me out.  Currently have a Biasi B10-4 boiler with a Carlin G3B ez gas burner.  Looking to replace the Carlin with a Riello.  In taking with Biasi, they recommend the 40 GAS120 burner which I cannot find.  However I can find a GAS200 that still falls within the heat output of the boiler.  Is there a reason why the 200 cannot be used on a B10-4?  Also, Biasi specifies a 3" insertion but the lowest the riello will go is 3-15/16". Will the extra length be an issue?
Any help is appreciated!
  • Big Ed_4
    Big Ed_4 Member Posts: 3,515
    edited November 2023
    The insertion is important with a tuned boiler . You can pull it back with longer flange studs and extra flange gaskets .... 1/2" you will be good
  • kcopp
    kcopp Member Posts: 4,663
    What wrong w/ the Carlin g3b?
    Steamhead Member Posts: 18,404
    It doesn't produce enough static air pressure to run well in that type of boiler.
    Consulting
    kcopp
  • PilotWerx
    The gas valve and blower motor need to be replaced.  As it is some special blower motor, the parts quote for both is $450.  For another $500 I can replace the whole unit.  I could also use the new carlin ez gas burner too.
