Needed 2" b&g flanged flow control valve. 2 flanges.
Adk1guy
Member Posts: 74
does anybody know where I can get a 2-in B&G flow control valve flanged on both the bottom and the outlet 90° configuration. An old customer has one that Froze and broke. whoever drained the system didn't open the flow control valve and let the water from above it out. Its way broke off very cleanly I am wondering about epoxying the two halves together. But obviously a new one
woulda be better and I cannot find them in any catalogs or a supply house lol. Please excuse the grammar I am using voice recognition
Are you sure it's not a triple duty valve?
Look up
MPN: 132131
Model: 3D-2S
If not, take a photo.
118095 Is the comple Dyna disc assy for the SA2 flo control. you might check with B&G on the prior # for part as there is one on ebay that they say is 118095 but the container for the part says FA7-62. That would be the old # but I could not cross that old # over. This way you could just pop the whole head and not have to break into piping. Works well as long as the part is correct replacement.0
He describes the flo control to be flanged x flanged.
SA flo control is not provided flanged x flanged
The triple duty is0 -
dko, it may be a very old flo control, but could be triple duty also. Thats why I told him to call B&G Tech support with #s off old one to verify correct part if still can get.0
