2 barometric dampers
jeremyred1
Member Posts: 3
hello hello I had a new oil furnace installed. Installer left the 2 existing dampers they are about 16" apart with a 90 elbow between . I feel the two dampers are pulling fumes from each other. Do I need 2? I have about 6 feet of 6" pipe with 2 dampers into a 4" power vent for 4 feet of 4 " then outside. Why would I need 2 barometric dampers? Thank you
2 barometrics and a power vent? Can you post a pic?All Steamed Up, Inc.
Consulting0 -
Here is a pic of the 2 dampers and the power vent on the left From the power vent it's about 4 feet of 4inch pipe to the outside thank you0
