Wonderful local Boilerless hydronic system
guzzinerd
Member Posts: 423
Today I had the pleasure of visiting a local ranch located at the base of a hill that supplies the area with cold and hot water springs.
All of the heating is radiant fed by the hot springs, no boilers, just pipes and rads.
Hot water Creek, it's chilly outside and the water temp is over 120°f.
Besides being crystal clear, the water is delicious (from the cold creek)
Uphill, are a few of these little cisterns where some of the water is collected and gravity-fed to the houses on the property.
There is a little booster pump for when the pressure is low.
Just thought I'd share.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
1
Is that The famed Salinas Valley Steinbeck wrote about? That would be how I'd picture it Mad Dog 🐕
Nice to access to that hot spring. Is there a heat exchanger in the hot supply somewhere. Those springs tend to have a lot of minerals in them.Bob "hot rod" Rohr
The pics I posted is all there is, no filters or anything else. It's really clean and not heavy at all.
