2 barometric dampers
hello hello I had a new oil furnace installed. Installer left the 2 existing dampers they are about 16" apart with a 90 elbow between . I feel the two dampers are pulling fumes from each other. Do I need 2? I have about 6 feet of 6" pipe with 2 dampers into a  4" power vent for 4 feet of 4 " then outside.  Why would I need 2 barometric dampers?    Thank you
    Steamhead Member Posts: 18,381
    2 barometrics and a power vent? Can you post a pic?
    Consulting
  • STEVEusaPA
    I’m guessing your overfire draft is way too high.
    You’re better off with a neutral pressure point adjuster.
    captainco
  • jeremyred1
    jeremyred1 Member Posts: 3
    STEVEusaPA
  • jeremyred1
    Here is a pic of the 2 dampers and the power vent on the left    From the power vent it's about 4 feet of 4inch pipe to the outside  thank you
