Zone valves not opening
scott6952
scott6952 Member Posts: 2
When I trip the thermostats  the boiler goes on but my zone valves aren’t opening
  • scott6952
    What do the 2 wires to the aqua stat actually do?
    EdTheHeaterMan Member Posts: 12,165
    More info needed. This sounds like you may have no heat. What type of zone valve do you have, Brand name and model number would help, or post a picture of them.
    The 2 wires probably are 24 volt control wires that connect the power from a transformer that is interrupted by the thermostat in order to open the valve to let the heat move through the pipes.
