Weil AB-80 Wall boiler heat only Manifold question
Trying to install a Weil AB-80 Wall Boiler myself and need some help understanding how a supplied Manifold, picture attached works. Not sure how the flow of water occurs when there is a straight pipe between the System Return #7 and the System Supply #6. how does the water flow into the boiler? The Manifold in case the picture is not clear has part number 383-100-061. Thanks so much if you can provide some assistance.
    EdTheHeaterMan Member Posts: 12,179
    edited November 2023
    This is called Primary/Secondary piping. It is used in order to isolate one pumping system from the other piping system. In some cases where there is a lot of restriction in a system, the pump that pushed the water thru the boiler is not strong enough to push the same water thru the entire system. if that happens the boiler heat exchanger may not get enough water to move across it to keep it from overheating. there is a good video about how it works. I'll try to find it for you
  • pini5205
    pini5205 Member Posts: 2
    Thanks for your quick response, for the explanation and video. Greatly appreciated.
