Help programming thermostat
Frankfog2
Member Posts: 44
Hey,
I need help properly programming the indept part of the thermostat. I have a Steam Boiler, they are balanced and function overall well. I had to replace the thermostat because it wasn’t turning the boiler on when it was supposed to. How do i set it up for steam heat? according to the manual default is set for forced heat.
https://www.honeywellstore.com/store/images/pdf/rth6360d-5-2-programmable-thermostat-manual.pdf
I have the same thermostat, mine is set up as follows
120- 0 (programmable thermostats are apparently not recommended in steam systems, that’s what my service guy told me)
125-0
200-3
205-12
Everything else i believe doesn’t apply, unless you’re using the thermostat for cooling as well in which case idk how to program that side0 -
Go into SET UP mode
once in setup mode scroll to number 200 and select 3 for boiler
then to item 205 and select item 12 for steam
If you want to use the setback feature, I would not set the night or away temperatures more than 5° lower than the at home temperature. But it would be better if you just left item 120 set at 0. Most steam systems are oversized and will recover quickly. But I seldom see any great savings on fuel usage. I would only use it for comfort reasons. Like if you want the room colder when you sleep.
- 116 Geothermal
- 169 Indoor-Air Quality
