eg 45 weil mclain boiler
polish_flash2000
Member Posts: 2
in Gas Heating
eg 45 weil mclain boiler - what is a proper voltage between Y & G terminal?
Can you post a pic of the wiring diagram?0
Going 100% by memory here,
But I think that's the connections across the thermostat? If so I'd expect it should be zero when the thermostat is calling for heat and 24V+- when it's not.
Looks like y and g are at the vent damper
I guess it depends on the age of the boiler.
I just went down and took this picture of the diagram on my 2011 EG series.
Thank you for all help.0
