eg 45 weil mclain boiler
eg 45 weil mclain boiler  - what is a proper voltage between Y & G terminal?
    HVACNUT Member Posts: 7,526
    Can you post a pic of the wiring diagram?
  • ChrisJ
    ChrisJ Member Posts: 17,519
    Going 100% by memory here,
    But I think that's the connections across the thermostat? If so I'd expect it should be zero when the thermostat is calling for heat and 24V+- when it's not.
  • realliveplumber
    realliveplumber Member Posts: 354
    Looks like y and g are at the vent damper
  • realliveplumber
  • ChrisJ
    I guess it depends on the age of the boiler.
    I just went down and took this picture of the diagram on my 2011 EG series.
  • Thank you for all help.
