Steam radiator - Stripped Thread
I’m a homeowner with very little plumbing knowledge.
Try screwing in a short 1/8" black nipple. That may clean it up. If it screws all the way and and is a little wobbly but can be pulled out. Use a lot quick wick clockwise and lots of pipe dope. Add a 1/8" Black couple on the end. Screw in your air vent. Try that first. Mad Dog 🐕1
Thank you everyone for the feedback. Posted photos and an update and hope to hear your thoughts.0
Is that a crack at the upper left? If it is cracked attempts to drill and tap larger or use a helicoil will not go well.0
I would try what Mad Dog said before trying more extreme measures. You may be able to get it to seal by doing as he says without any further drilling or tapping.
"Quick wick" may not be readily available to you, but you can get it on Amazon:
https://www.amazon.com/Loctite-442-35082-Length-Sealing-Off-White/dp/B000ORA0MM/ref=sr_1_1?crid=2HALOURWKP1NQ&keywords=plumbing+quick+wick&qid=1696433628&sprefix=plumbing+quick+wick,aps,93&sr=8-1
And there are many types of pipe dope, but I've had good success with this:
https://www.amazon.com/Rectorseal-23631-Brush-Thread-Sealant/dp/B0002YPAFY/ref=sr_1_1_sspa?crid=1WGRNSH9WTW7A&keywords=rectorseal+t-2&qid=1696434105&sprefix=rectorseal+t-2,aps,104&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Apply both to a 1/8" black iron nipple (with coupling for the vent) from Home Depot as Mad Dog said. You may find that's enough to seal it.2 -
mattmia2 said:Is that a crack at the upper left? If it is cracked attempts to drill and tap larger or use a helicoil will not go well.0
How far in do the vents go... meaning are they close to bottoming?
If not, then get a 1/8" NPT tap and carefully run it in, once it's started in the same threads drive it in deeper but don't go crazy. If you go too deep, then you'll bottom the connection out without making a seal. You don't want to drive the tap any further in than necessary to get good threads. Also be careful it doesn't physically hit the inside of the radiator and stop it self. You'll pull the threads out if that happens and you keep turning.
It's a tapered thread, so it's designed to wedge together.
I'd want 2 threads or so exposed when fully tight worse case. On my radiators I chased all of the threads but kept it so the vents only screw in 3 turns or so. That leaves me plenty of meat in the future to go deeper. When I got there they only went in 2 turns.
If it's stripped and too bad to clean up by going a little deeper, I'd do as others said and drill and tap for 1/4 NPT and then use a 1/4 to 1/8 bushing.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Air vents are brass (softer) so their threads don't usually strip the cast iron female tappings. 95% of the time, my black nipple does the trick. Mad Dog 🐕4
X 3 on the heli coil.0
Its a stainless steel insert. Resembles a wound spring. Diamond profile. Slightly oversized, and requires a special tap with a standard size drill bit. Installing a 1/8" npt heli coil will remove less material than going up to 1/4" npt.
I used a ton of them in a past life. Mostly machine threads, not many npt.1 -
there is something about you need to use a taper reamer in there if you want it to end up tapered too.realliveplumber said:Its a stainless steel insert. Resembles a wound spring. Diamond profile. Slightly oversized, and requires a special tap with a standard size drill bit. Installing a 1/8" npt heli coil will remove less material than going up to 1/4" npt.
the insert can unscrew from the hole but in something delicate like that it might be the better option0 -
jesmed1 said:I would try what Mad Dog said before trying more extreme measures. You may be able to get it to seal by doing as he says without any further drilling or tapping. "Quick wick" may not be readily available to you, but you can get it on Amazon: https://www.amazon.com/Loctite-442-35082-Length-Sealing-Off-White/dp/B000ORA0MM/ref=sr_1_1?crid=2HALOURWKP1NQ&keywords=plumbing+quick+wick&qid=1696433628&sprefix=plumbing+quick+wick,aps,93&sr=8-1 And there are many types of pipe dope, but I've had good success with this: https://www.amazon.com/Rectorseal-23631-Brush-Thread-Sealant/dp/B0002YPAFY/ref=sr_1_1_sspa?crid=1WGRNSH9WTW7A&keywords=rectorseal+t-2&qid=1696434105&sprefix=rectorseal+t-2,aps,104&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1 Apply both to a 1/8" black iron nipple (with coupling for the vent) from Home Depot as Mad Dog said. You may find that's enough to seal it.
@Giants9890 No, not aluminum for the coupling! You want iron. Let me find a link for you.
Here ya go:
https://www.amazon.com/Anvil-8700132957-Malleable-Fitting-Coupling/dp/B0058DHZSY/ref=sr_1_4?crid=9EI2OV3W6H1Q&keywords=1/8+black+iron+coupler&qid=1696469789&sprefix=1/8+black+iron+coupler,aps,90&sr=8-4&th=11 -
Hi All, images of the old radiator valve, newly purchased nipple, and all items purchased. The nipple will not screw in to the hole. It appears the old valve lost its threads inside of the radiator. What can I do now? Thank you for helping me through this as this bedroom turns into an oven.
Please see my post from October 4th.Giants9890 said:Hi All, images of the old radiator valve, newly purchased nipple, and all items purchased. The nipple will not screw in to the hole. It appears the old valve lost its threads inside of the radiator. What can I do now? Thank you for helping me through this as this bedroom turns into an oven.
That will still fix the problem.
Buy an 1/8" NPT tap and a handle that works with it. I would not use oil with the tap.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Tap it (I have done my share in the past. Oil or not, but go slow and stay straight. If you feel too much resistance, then back it out and start again. The last thing you want to do is snap off the tap in the hole. You might want to practice on another piece of metal by drilling the required hole so you get the feel of it. I usually use the oil, as there won't be so much to mess-up the system.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 961 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
