PEX loop idea - smart or not?
What do you think?
Three two inch bits of aluminum at the end of each loop. In my particular case, thirty joist spaces. So that's an extra fifteen feet of aluminum - probably not a huge amount of difference. But if I could have run four extra 48" contiguous aluminum plates I definitely would have. If I have the time (and I probably should work on other things) there's definitely no harm, right?
    hot_rod Member Posts: 27,453
    no to the one the end. The loop needs to be able to expand  and contract
    GroundUpmattmia2
  • SteamtoHotWater
    SteamtoHotWater Member Posts: 123
    Got it.
    Though at four inches instead of six, it seems even less worth it.
  • STEVEusaPA
    Leave it. Watch what happens...lol
    Why would you do that in the first place?
  • SteamtoHotWater
    Think I'm going to do two, 2.5" pieces - an extra 12 feet of aluminum.
