PEX loop idea - smart or not?
SteamtoHotWater
Member Posts: 123
What do you think?
Three two inch bits of aluminum at the end of each loop. In my particular case, thirty joist spaces. So that's an extra fifteen feet of aluminum - probably not a huge amount of difference. But if I could have run four extra 48" contiguous aluminum plates I definitely would have. If I have the time (and I probably should work on other things) there's definitely no harm, right?
Got it.
Though at four inches instead of six, it seems even less worth it.0 -
STEVEusaPA said:
Why would you do that in the first place?
Think I'm going to do two, 2.5" pieces - an extra 12 feet of aluminum.SteamtoHotWater said:But if I could have run four extra 48" contiguous aluminum plates I definitely would have.
- 125 Chimneys & Flues
- 19 Recall Announcements
